 Post subject: Some boards to check
PostPosted: Mon Jul 29, 2019 6:16 pm
Thanks
 Post subject: Re: Some boards to check
PostPosted: Tue Jul 30, 2019 9:22 pm
20190725_201458.jpg - I'm leaning towards small socket motherboard given the expansion slots that are present and heavy IC density in the lower right corner.
20190725_201601.jpg - peripheral
20190725_201754.jpg - small socket, due to what appears to be a pinless ceramic CPU soldered to the board and several other flat pack ICs present.
20190725_201806.jpg - peripheral
20190725_201906.jpg - peripheral
20190725_202018.jpg - telecom
20190725_202055.jpg - peripheral
20190725_202228.jpg - telecom
PostPosted: Wed Jul 31, 2019 1:48 pm
I’ve been strongly hesitant to do this but kgryczan, I don’t think 20190725_201754 will make it to motherboard. Despite the soldered Cpu, bridge chip, and internal ports it’s missing both ram expansion and external gold pin connectors. It’s also under populated for the size. With nothing to offset the weight of the bare board, and only one cpu, I think this is still firmly in peripheral. Just not enough there to bump it over.
I’ve been looking at that for a few days now and the more I do the more I know it would go in my peripheral pile; though it would have sat out a few days as I made up my mind.
however
Op, post the back side. It looks like there’s some pinthrough on the right side of the board. If there’s any ICs on the back this could all be a moot point, as it may jump to low telco.
PostPosted: Wed Jul 31, 2019 10:45 pm
K i will check
