It is currently Wed Aug 05, 2026 12:22 pm
PostPosted: Mon Aug 05, 2019 12:35 pm
I have several thousand boards the same or similar to these. Looking for any insight on how they would be classified? Thank you!
-Jeff
PostPosted: Mon Aug 05, 2019 12:57 pm
peripheral
barely peripheral remove the speaker
barely peripheral remove the fuse
PostPosted: Mon Aug 05, 2019 1:22 pm
Can you clarify the fuse? There is a vibrator motor, is that what you are looking at? Also, should LCD's typically be removed as well?
Thank you for the feedback!
-Jeff
PostPosted: Mon Aug 05, 2019 2:49 pm
Nice! The one time in a hundred I actually pull a request up on my monitor and the big picture makes a problem. Lol. From my phone yes! It’s definitely a motor. I see the little off balance weight at the end. ;)
Wires always need to be removed, as well as any glass fuses. And all batteries excluding sealed cell phones.
Screens should be removed unless they are glued, soldered, or welded into the board. The right (wrong) tips of screen can very quickly drop a board out of its class down to midgrade, or worse. Especially vacuum lcd screens.
