It is currently Fri Oct 30, 2026 12:38 am
 Post subject: board grade
PostPosted: Tue Aug 13, 2019 3:36 pm
Have this HP board. pull the cpu or leave it? What grade with/without cpu?
Hoarder turned scrapper.
 Post subject: Re: board grade
PostPosted: Tue Aug 13, 2019 5:40 pm
That cpu is almost surely soldered.
It’s gold cap chip board. Don’t remove it as you’d loose money.
UNLESS it’s a pin through. AND you can 100% guarantee to keep all the pins intact.
If you do remove the cpu as above; the board is small socket motherboard and the CPU with all pins would get a downgraded rate. I’ve sent a few over the years, so called stub pin processors, and Chris has a methodology in place to cover them fairly due to the shorter pins.
