It is currently Wed Oct 28, 2026 11:01 pm
 Post subject: Boards for grading #2
PostPosted: Mon Aug 19, 2019 8:23 pm
For the bottom board I was thinking peripheral, for the laptop motherboard I am assuming large socket, could I put the heat spreader in with my gold pins? For the calculator boards I was thinking midgrade. All help is appreciated.
Thank you!
PostPosted: Tue Aug 20, 2019 12:10 pm
Assuming the little brown one is front and back :
Peripheral, please remove batteries
Soldered cpu, bridge chips, controllers, internal and external connectors, and soldered ram. Looks like these should survive small socket motherboard.
Last set
Looks like a keyboard. Flashing. No extraneous weight. Good for peripheral.
PostPosted: Tue Aug 20, 2019 2:14 pm
Thank you for helping me get these boards graded!
PostPosted: Wed Aug 21, 2019 8:49 am
Second board came from a vintage laptop, decent amount of I.C chips with older gold bonding wire.
You might want to double-check with Chris on that one, unless grading has changed so significantly that some old laptop boards would now go as small socket.
It is a laptop motherboard, I have pulled one before from a few years back but how its buyer would grade it as scrap material regardless will all be up to him, just try and see what he says.
Good Luck.
PostPosted: Wed Aug 21, 2019 6:34 pm
Rubble has a point. This is right at the edge between a full fledged laptop board (large socket) and a high end modern netbook or embedded board (small socket).
I’ve had similar boards, from all the above, fluctuate across the threshold. While I still suggest quoting as small socket I’d also suggest bundling them together separate from the other stalls as they could get an upgrade.
PostPosted: Thu Aug 22, 2019 1:03 pm
I have put it aside to ask, it came out of a old Toshiba laptop.
Thank you.
