It is currently Sat Aug 29, 2026 10:20 pm
 Post subject: Sorting help
PostPosted: Wed Aug 21, 2019 6:16 pm
I’m thinking peripheral on all?
 Post subject: Re: Sorting help
PostPosted: Fri Aug 23, 2019 9:22 pm
The one with the screws is midgrade; rest are peripheral
PostPosted: Wed Aug 28, 2019 7:53 pm
Thanks Lost!
PostPosted: Wed Aug 28, 2019 7:57 pm
What about these two mid grade? They came from a dart board
PostPosted: Fri Aug 30, 2019 1:15 pm
Those are dart boards are low grade boards. Even though they are green on the one side, they are still of very low quality and value.
PostPosted: Fri Aug 30, 2019 1:57 pm
The only thing of value there to boardsort is the screen controller. If you cut it loose you’d get peripheral for that piece.
The actual displays do contain some tin and silver but also contain mercury and boron. I’ve had them safely tested by a professional. Who quickly said don’t bring any more. ;)
I don’t believe Chris actually wants that display board. They tend to turn back toxic chemical boards. So unless he reply’s back don’t send that one in.
I have a box of those displays that I’ve carefully removed (after extensive experience to do so safely) that will eventually be brought to a hazmat collection. Mercury is a neural-toxin, boron is just a problem in general.
PostPosted: Fri Aug 30, 2019 10:44 pm
Well... on an optimistic note there is still one ic chip between both boards I can take off and add to my next shipment.
PostPosted: Wed Sep 25, 2019 5:23 pm
What if I did this?
PostPosted: Wed Sep 25, 2019 6:56 pm
Looks like that board may get peripheral depending on the back side.
PostPosted: Thu Sep 26, 2019 12:49 am
look at pic
and
same board now with removed wire jack.
