 Post subject: Relay Boards
PostPosted: Sat Aug 31, 2019 3:31 am
1) Same board, both sides.
2) Group of relay boards.
 Post subject: Re: Relay Boards
PostPosted: Sat Aug 31, 2019 10:46 am
Top midgrade
Bottom. One in the middle should just make peripheral. One on the right is midgrade so remove the socketed IC
PostPosted: Sat Aug 31, 2019 8:16 pm
What would bottom left be?
PostPosted: Sat Aug 31, 2019 8:33 pm
Midgrade
You can safely trim the fingers here and still be midgrade, if the connector is indeed gold.
If you plan to ship midgrade leave the serial port on.
Assuming this falls with 99% of such controllers; with gold pins for the port: If you don’t plan to ship the board you can remove the serial port off for gold pin connector.
