It is currently Wed Oct 28, 2026 11:08 am
 Post subject: Board for grading #19
PostPosted: Sat Sep 21, 2019 8:33 pm
Below are three different boards. Each of these have multiple socketed chips. For whatever grade, can the socketed chips be removed?
Thank You!
PostPosted: Sat Sep 21, 2019 10:57 pm
Peripheral: leave the white ones in and pull the rest... you’ll have enough to maintain the grade
Peripheral as is so don’t pull
Barely peripheral; don’t pull
PostPosted: Mon Sep 23, 2019 8:46 am
I need to stop ripping off the copper bearing/motor weight if these are still being called peripheral. I always thought a board was automatically mid grade with those left on.
PostPosted: Mon Sep 23, 2019 9:25 am
The last two are right at the edge of the grade. I believe they’ll clear it but I’m not positive. My grades are mine. I’m usually correct but not always
PostPosted: Sat Sep 28, 2019 11:50 am
Lostinlowdos, Thank you. I was wondering about the bottom two. The boards have pretty good chips, but the transformers are rather quite heavy.
