 Post subject: Some more telecom boards
PostPosted: Mon Nov 04, 2019 9:20 pm
What would these fall as?
In the first pic all 3 boards on the top are from the same card (fit together via pins on the boards).
In pic4 both boards are from the same card.
Thanks
PostPosted: Tue Nov 05, 2019 12:40 am
Second photo is high telco.
Be back on the first later
PostPosted: Tue Nov 05, 2019 3:54 pm
P-peripheral
Lt-low telco
Ht-high telco
PostPosted: Tue Nov 05, 2019 7:29 pm
Thank you.
I have a question on the first picture. All 3 boards are slotted together in the same card. If the card was left intact what would it fall as?
Pic attached of the card not pulled apart..
PostPosted: Wed Nov 06, 2019 7:27 pm
Peripheral
PostPosted: Wed Nov 06, 2019 9:43 pm
Thanks.. Good to know, so pulling them apart is the best route to go
PostPosted: Thu Nov 07, 2019 2:24 am
Correct.
In many such cases you could end up aT midgrade . It’s usually best to separate such assemblies
PostPosted: Fri Nov 08, 2019 7:20 pm
lostinlodos wrote:
Correct.
would that go as a ''teardown/small electronic'' or something like now ? witch would be worse than even midgrade..
PostPosted: Fri Nov 08, 2019 7:26 pm
I’d reason not. It’s four thumb screws. If the dock worker is in a really good mood they may even pull it apart for you but I wouldn’t count on that.
PostPosted: Fri Nov 08, 2019 7:37 pm
lol after some of my earier shipments it would be the latter ..
