 Post subject: Boards for grading #7
PostPosted: Fri Nov 08, 2019 5:19 pm
Boards from a plasma monitor and a slot filler from a computer.
Thank you!
PostPosted: Fri Nov 08, 2019 7:22 pm
Midgrade/blank ram
All peripheral
Both midgrade
Big one just barely peripheral/little one if on plastic peripheral, if on aluminium midgrade. If you manage to peak it loose you’ll get IC chips and mixed wire . Just be gentle... those bump chips are easy to crack, crush, and destroy.
PostPosted: Fri Nov 08, 2019 7:32 pm
Could I trim the finger on the slot filler? I tried to get the wire off and it just tore leaving the ic chip on. The ic appeared to have a white glass in it when I tried to bend the aluminum.
PostPosted: Fri Nov 08, 2019 7:35 pm
Thank you!
PostPosted: Fri Nov 08, 2019 10:11 pm
If you trim the fingers off it will be low grade.
PostPosted: Sat Nov 09, 2019 5:41 pm
Ok.
Thank you.
