It is currently Sat Aug 29, 2026 11:08 pm
 Post subject: Curious about this board
PostPosted: Wed Nov 06, 2019 9:14 pm
Out of a modulating video processor unit..
Are those 2 chips gold cap on the bottom left?
Thanks
PostPosted: Wed Nov 06, 2019 9:46 pm
Thanks
they are ,witch make that a Gold Cap Chip Board even know its on the low end of the scale.(if there was a scale)
PostPosted: Thu Nov 07, 2019 2:12 am
Do NOT remove anything socketed.
This is an example that inadvertently games the system. :)
PostPosted: Thu Nov 07, 2019 9:33 pm
Thank you both..
PostPosted: Mon Nov 18, 2019 4:59 pm
Thanks
Wow, i need to post boards on here more often. If I removed that board from whatever, I would have assumed I would have to rip a lot of those transformer type (not sure what they are called) pieces off of that boards and throw it in my Peripheral board bin.
PostPosted: Mon Nov 18, 2019 5:09 pm
Stuff like this is rare. As I said it really games the system. But the IC population would have just cleared the peripheral rate. The gold cap chips cheat the system by pushing it into gold cap chip board.
PostPosted: Mon Nov 18, 2019 11:38 pm
[yeap,]
but
based on average the low end was factored in the boardsort prices almost has to be ..
PostPosted: Tue Nov 19, 2019 12:24 am
Btw looks like R295 is the culprit. On the off chance you have any intention on a repair. Few capacitors are damaged from age or abuse (not blown) and could be re seated or replaced.
You’ll need a new resistor and probably a trace bypass. The pt for 295 looks shot but the resolution is too low to be sure.
There could well be other issues but that one stands out.
PostPosted: Tue Nov 19, 2019 9:45 pm
Thanks, no it was sitting outside when I got it, already all tore apart..
