Merkman wrote:
(Not looking for the “what is your time worth” schpeel haha I just don’t see how, generally, practically, these might be worth breaking down)
For most. No.
If you recycle a lot the ease of literally breaking them open with a 2” screw driver and a nail and screw trimmer makes controller extraction quick and simple.
Doing it “correctly” takes a few minutes
Going horror film on it takes seconds for most drives.
Stab stab stab cut pull pop.
Stab the three longest sides along the edge half way between the corners.
Cut vertically on the longest side, through the case, components whatever
Pull the shell (use gloves or grips) open sardine can style.
Line up your driver under the middle screw under the board and pop.
$0.60 per minute is $36 per hour. Not bad in my book.
