It is currently Sun Nov 01, 2026 6:07 pm
PostPosted: Sun Dec 01, 2019 2:01 am
I'm assuming these are gold instead of brass but I could be wrong. This was tucked away under the top belly of an old IBM server.
Thanks for your reply.
PostPosted: Sun Dec 01, 2019 3:05 am
Actually, they're both. Gold plate over yellow brass.
PostPosted: Sun Dec 01, 2019 3:23 am
Yep. While the exposed part is brass, if you were to break the plastic off you would see the end of the plating
PostPosted: Sun Dec 01, 2019 3:52 am
Brass- Fooled my ass.
In regards to what type of board this is would it fall under midgrade?
PostPosted: Sun Dec 01, 2019 4:57 am
There’s usually a tiny amount of gold plating under the plastic at the connection point for electrical stability. (The blue connectors)
In case you’re interested in breaking into the connectors to find out.
Regardless: the board is midgrade. There’s enough brass weight for the value over low; despite missing ICs.
