 Post subject: mixed lot of small junk
PostPosted: Mon Jan 27, 2020 12:07 pm
Best guess... left to right... Peripheral (or maybe just gold connetor), peripheral (maybe mid-grade), Peripheral, Periphial (or maybe just gold connector)?
PostPosted: Mon Jan 27, 2020 9:27 pm
They should all clear peripheral.....I would see what Lost says for sure.
What is the long black one out of?
PostPosted: Mon Jan 27, 2020 11:09 pm
Believe it’s either a display controller or a drive controller. Cut the board end off and the connectors end off for a grand total of 5 peripheral boards. And one piece of mixed wire.
Btw keep the third one from right sorted separate. It may get an upgrade. I’m not sure offhand what from but that’s an antenna board.
PostPosted: Mon Jan 27, 2020 11:17 pm
Did someone strip an apple. I’m almost positive that ID label on the 3rd one is an older Apple label.
PostPosted: Wed Jan 29, 2020 5:26 pm
lost is on point as usual.
A white body MacBook from around 2009. I think it came from the touchpad... but not 100% on that.
The one next to it is the wireless nic for the same model
the one next to that is a old Sandisk flash drive with the gold fingers removed.
the first one... no clue what it came out of lol
PostPosted: Wed Jan 29, 2020 8:56 pm
I thought that was a CF or PC Card. ;)
I was close.
The unknown one is some sort of I/o relay board. I’ve definitely seen them but without coming across it again inside something I wouldn’t be able to pinpoint it exactly.
