 Post subject: Kind of Board?
PostPosted: Fri Feb 27, 2015 2:41 pm
The pics are all of the same thing board/boards but what kind of board is it and could and what should i take off the keep it the same value? Sorry I know that is confusing if you have any questions just ask and I will clarify.
File comment: #1
File comment: #2
File comment: #3
File comment: #4
 Post subject: Re: Kind of Board?
PostPosted: Fri Feb 27, 2015 2:52 pm
They are low grade. I wouldn't ship those due to the cost of shipping. You can remove the aluminum heat sink and the ic chip to sell separately. If you are not near the Boardsort facility you can sell the boards and the aluminum locally. I would save the IC Chips to ship to boardsort once you have a good quantity.
PostPosted: Fri Feb 27, 2015 2:56 pm
Thanks I'm new at this so that really helped!
PostPosted: Fri Feb 27, 2015 9:47 pm
If you have a nice qty of these boards, there sure is pretty good supply of aluminum, copper wire and even shred steel. IC chips look good too! Yes, local scrap yard is the best place unless you can mix those in with higher value boards to offset them.
