It is currently Sat Aug 01, 2026 4:18 pm
PostPosted: Thu Feb 26, 2015 8:26 pm
I am new to this and yet to send in a load because I need to understand proper board classification. Here are a few pics of some boards and my guess is that they are mid grade but hoping that I am wrong. Any transformers and other heat sinks, copper or easy to remove IC chips have been removed since I figured that those are worth more at local scrap yard. I would sell the IC here when i get enough. On the board with the LED screen (or is it a different type of screen) does it have to be removed first? Will it change the value/grade of that board?
Can any of the experts here tell me if I am doing this correctly? Would you do anything different?
Great forum here, learning a lot!
PostPosted: Fri Feb 27, 2015 9:37 am
I think you are doing everything right. Board 1 and 2 are mid grade if green on both sides. You can still remove the ic chips with a small flat head screw driver to sell to boardsort. Just be gentle otherwise you could brake the ic chip. The other board I would say is peripheral only if you remove the LED screen
PostPosted: Fri Feb 27, 2015 9:33 pm
Thank you for your help. Been spending lots of time here reading other posts to help figure this stuff out! Great information here!
