It is currently Thu Aug 06, 2026 12:14 am
 Post subject: New boards for ID help
PostPosted: Sun Feb 23, 2020 1:10 pm
Just a couple more to double check sort
PostPosted: Sun Feb 23, 2020 1:56 pm
1,2,&4 are peripheral
3 is midgrade, and I don't think it could ever make peripheral, if you start pulling that metal.
If 6 has a chip on the other side, peripheral, if not, gold pin connector
Peripheral@ $1.60/lb ATM is the lowest value material I PERSONALLY will attempt to ship to BoardSort (from FL), so if your shipping to them I'd suggest pulling the pins from that connector board, you'll lose overall sale value but I can't figure out how to afford shipping GPC@.50, clean gold pins however, @$5/lb is a much more attractive option to me, especially since a bag of pins is one of the densest things I'll be shipping (potentially rivalled by ceramic processors)
As for the midgrade, unless you get a really good price locally (how good depends on how much you value your time but at least 20¢/lb which I only get 8) tear them apart as much as you can, lots of metal for local yard, and ics for BoardSort ($6.75/lb awesome)
Representin otown, central FL
PostPosted: Sun Feb 23, 2020 2:36 pm
1)Peripheral
2)Peripheral
3)Low
4)Small socket
6)Peripheral
3 is just a power box without the shell. Despite being green there’s no room to bump it to mid.
4 is REALLY borderline. I’ve had, and been told of, compact boards like this CE going both ways. Ultimately is up to the person at the dock.
PostPosted: Sun Feb 23, 2020 3:17 pm
Thanks guys for the help and info.
