It is currently Sat Sep 26, 2026 6:28 am
PostPosted: Mon Feb 24, 2020 8:21 pm
The board with gold fingers is also a Wire Wrap board with 2inch long heavy plated gold pins.
The 2nd board is military grade and not a wire wrap board but on both boards the gold capped chips have gold legs. Thanks for any help
PostPosted: Mon Feb 24, 2020 8:49 pm
Now I won't be able to sleep until somebody lets us know...
PostPosted: Mon Feb 24, 2020 9:14 pm
Both are the definition of ideal gold cap chip board.
Only because I don’t see anything indicating a wire wrap plane.
PostPosted: Tue Feb 25, 2020 8:54 am
On the second board would it be a smart idea to remove all the gold cap chips? They all appear to be in a socket, while on the first board you can't remove them.
PostPosted: Tue Feb 25, 2020 12:57 pm
Yes but they are not loose socketed. They are through hole and solder in place in-socket or underneath.
If you opt to remove the ICs, for a much better payout, you need to be careful. There’s a good possibility with a board Like this of lead soldier. You also need to completely remove the ICs with pins for 8086 rate.
So you would need to use a desoldering method (solder pen, heat gun etc) in open air/good ventilation, and with a respirator.
Boards like this I’d actually suggest calling Chris or emailing a photo and asking first. See if they would offer a custom quote for a nearly complete gold cap population.
Removing gold caps from these will always be the highest payout but please do so safely.
PostPosted: Tue Feb 25, 2020 1:39 pm
The first board the chips are soldered, the second board is wire wrap with socketed chips
PostPosted: Tue Feb 25, 2020 2:00 pm
No your wrong, the wire wrap board the chips come right out, no solder, the military board yes they're soldered
PostPosted: Tue Feb 25, 2020 2:15 pm
Ah, wicked. Major score.
YES pull the socketed ICs!
PostPosted: Tue Feb 25, 2020 3:33 pm
Cool thanks, I have some more Military boards Ill need to send pics to see whether they are telecom or large socket but thanks for the help
