It is currently Thu Sep 10, 2026 6:14 pm
PostPosted: Fri Mar 13, 2020 6:49 pm
Any tips on removing heat sinks from old ceramic CPUs? I have two stubborn ones I can’t seem to get the heat sink off.
PostPosted: Fri Mar 13, 2020 8:47 pm
Personally I use slipjaw pliers (robo-grip). Parallel to the board around the sink and turn counter clockwise.
Some need to be heated. Try a hair dryer or heat gun. Chris has suggested boiling.
PostPosted: Tue Mar 17, 2020 12:31 pm
I ended up boiling them for a few minutes, then taking a bit of dental floss to the gap. After a bit of circulation loss in my fingers they removed with a swift wack of the hammer.
PostPosted: Sat Mar 21, 2020 5:51 pm
heat gun or torch. Heat up and use channel lock pliers to twist the heat sink off.
Hoarder turned scrapper.
PostPosted: Sat Mar 21, 2020 7:05 pm
FYI don’t ever use a torch on fibre CPUs
PostPosted: Sat Mar 21, 2020 7:13 pm
Good point. :-)
