It is currently Mon Jun 22, 2026 5:54 pm
 Post subject: CPU
PostPosted: Sun Apr 26, 2020 1:19 am
#4 has an issue. The heatsink won't come off. Whatever's holding it on doesn't look like any thermal compound I've seen. Guessing it's thermal adhesive. Any ideas how to get it off? Heat gun, maybe?
 Post subject: Re: CPU
PostPosted: Sun Apr 26, 2020 2:50 pm
1)pentium/Mac ceramic
Gently peal the wire board off and put it in peripheral
2)I believe that will go AMD ceramic
3)Pentium Mac ceramic
4)AMD aluminium cap as is. Chris says boil them. Takes a bit but does work.
I use a heat gun. Not as safe for the chips but much faster.
I found 300-400• at about 6-12 inches away works for these. Pins up. Hold or mount the gun towards a SIDE at a 45• grade above it. About a minute or so you should be able to slide a small screwdriver into the space and pull the putty loose. Repeat three more times.
Without heatsink it’s pentium Mac ceramic so worth the effort
PostPosted: Sun Apr 26, 2020 8:59 pm
It's not 386/486 Gold Cap? It looks like the picture for that on the payout page.
http://boardsort.com/images/codes/3014.jpg
PostPosted: Sun Apr 26, 2020 9:09 pm
While we're on the subject, what are these?
PostPosted: Mon Apr 27, 2020 12:25 am
I have no way of telling with the heatsink attached what it is beyond being a gold cap cpu
PostPosted: Mon Apr 27, 2020 12:26 am
Looks like a mix of foreign (original pentiums) gold caps and 386. The other side is vital for id
PostPosted: Mon Apr 27, 2020 9:06 pm
I got the heatsink off and I took front and back pictures. I mistakenly assumed the side with all the gold was all I needed to show.
PostPosted: Tue Apr 28, 2020 12:40 am
There you go! 386/486 across all of em
