It is currently Wed Jun 03, 2026 5:34 pm
 Post subject: Gold Cornered ic chips
PostPosted: Wed Mar 19, 2014 2:05 pm
What's the best way to remove the ic chips with the green board and gold corner?
PostPosted: Wed Mar 19, 2014 7:01 pm
Some use a heat gun for a couple minutes, Myself I use a standard propane torch, heat the chip up a few seconds then tap the board on the table, if it doesn't come off give it a couple more seconds of heat. It sure beats using a screwdriver.
PostPosted: Wed Mar 19, 2014 7:19 pm
Are they worth the same as other ic chips?
PostPosted: Wed Mar 19, 2014 8:10 pm
They are worth more then double, In this thread (viewtopic.php?f=4&t=65) I was quoted $16.50 a pound.
PostPosted: Wed Mar 19, 2014 9:06 pm
Do the chips have to be completely intact or can the ceramic be broken?
PostPosted: Wed Mar 19, 2014 10:01 pm
That I don't know, I would imagine it wouldn't matter as the ceramic doesn't have any real value, just the gold under it. Best to get an answer from Boardsort on that.
PostPosted: Wed Mar 19, 2014 10:28 pm
Thanks for the tips
PostPosted: Wed May 21, 2014 11:59 am
actually the ceramic contains the bulk of the PM's in the form of gold bonding wires. The gold you see on the green fiber underneath is actually just flash plating and amounts less than 20% of Au content.
PostPosted: Fri May 23, 2014 2:32 pm
Agreed. The entire cpu must be intact if you would like the full value.
PostPosted: Sun Nov 21, 2021 5:42 pm
I know this post is years old.
But for some us that don’t have or want a heated air gun or chisel.
Try flexing/bending the board both ways where the chip is, you’ll hear some pops, then simply pry off easily with a screwdriver where there is space at the edges.
And yes apparently the black cap is where most of the gold bonding wires and value is.
