It is currently Sun Aug 02, 2026 7:46 pm
 Post subject: Need help grading
PostPosted: Thu May 21, 2020 4:34 pm
Just wondering what these would be graded as thanks
 Post subject: Re: Need help grading
PostPosted: Fri May 22, 2020 7:16 pm
Sorry. Not ignoring this. Your post is Just longer than the norm And the photos are lower resolution.
I wanted to take my time so here I go:
50)peripheral
31)Low telco
33)peripheral
63)peripheral
53)peripheral
65)low telco
88)peripheral
73)Low telco
14)peripheral
36)Low telco
81)peripheral
31)Peripheral
PostPosted: Sat May 23, 2020 8:51 am
Did you catch the hint, Coreyhg 1989?
Shorter sets of photos require less time to answer, so generally will be ID quickly Also, better pics allows one to see the critical components for classification easily, without straining to see if the pins and connectors are gold or nickel, etc. Don't get so involved with getting every pic posted on the same post that you make it more difficult for Lost.
Actually, I am posting this for my own utilization. When I see a post with so many photos, I scroll down quickly, just glancing at the photos, to look at the identification, and then go back to match up the id with a particular board.
PostPosted: Sat May 23, 2020 1:10 pm
Honestly it’s more important to have have some sort of numbering system to mark boards. A b c f d 1 2 4 17 3 lol.
The point, here and the rules post, is that if it works out to more than 3-6 boards or so i can’t do it in quick down time.
Even resolution isn’t a killer. Just light things up better. Use a flash or brighter room. Again I do most of this on my phone. So any glare on my screen washes out darker low resolution images.
Not at all your problem. Admittedly!
But bright or high res gets it done anywhere I can pull out my phone.
PostPosted: Sat May 23, 2020 11:07 pm
Thank you, and sorry about that will stick to 4 or less pics from now on.
