 Post subject: IC?
PostPosted: Wed Mar 19, 2014 11:45 pm
Hi,
I am just about ready to send in my first shipment? Is this an IC chip?
On a personal note: I really appreciate this forum and site.
Big Red
File comment: Backside
File comment: Side one
 Post subject: Re: IC?
PostPosted: Wed Mar 19, 2014 11:55 pm
It is possible, the term it is called is a "convergence correction circuit IC" The one you have pictured came out of a projector.
http://www.mcmelectronics.com/product/S ... STK392-110
PostPosted: Thu Mar 20, 2014 12:09 am
scob89, Thanks for your response. Do you think Boardsort will buy it as an IC?
PostPosted: Thu Mar 20, 2014 12:35 am
I don't know, I have never sent one in. Still waiting to build up more material before I send more in.
PostPosted: Fri Mar 21, 2014 12:55 pm
We would not buy that as an IC chip only because I have been unable to find any value data. It could be as worthless as a resistor/capacitor, unfortunately there is just not enough information to be able to make a reasonable assessment. Sorry!
PostPosted: Fri Mar 21, 2014 11:50 pm
Thanks for the info. I only have a few, so I'll pull them from my bin.
PostPosted: Sat Mar 22, 2014 6:35 am
Is that the one made out of aluminum and has the green board glued to it between the aluminum plate and the ceramic on the outside?
PostPosted: Sat Mar 22, 2014 9:46 am
Just a thought here, perhaps when you send you next shipment in you could include a couple of these chips for Boardsort to test?
PostPosted: Thu Aug 21, 2014 7:38 pm
kandksalvage, sorry for the delay. Yes it is, made out of aluminum and has the green board glued to it between the aluminum plate and the ceramic on the outside. Photo attached of it broken open.
