PostPosted: Fri Jun 12, 2020 1:46 pm
Contestants will be separated into groups
Table 1
File comment: Table 1
Representin otown, central FL
PostPosted: Fri Jun 12, 2020 2:14 pm
Mixed boards
Peripheral. Someone stole a gold cap from you.
Remove the two giant capacitors for peripheral
Peripheral
Depends on the back. Midgrade at the moment
Peripheral
Peripheral/gold pin connector
Gold pin connector
Big: remove the shield. Cut both glass fuses off. Do NOT unscrew screws. Peripheral. There’s enough nickel to balance out
Smaller: probably midgrade. If it has the two large ICs on the back peripheral but I believe this board has a second daughter board
PostPosted: Fri Jun 12, 2020 2:29 pm
Bottom is back of middle, top is different shape but pretty much the same, one of those round (ic?) Bumps and some flashed contacts where ribbon wire attached,
I think calculators? Or maybe phones, I forget, pulled out of low grade to ask
PostPosted: Fri Jun 12, 2020 3:56 pm
Midgrade then.
