PostPosted: Wed Mar 25, 2015 2:59 pm
I have this sun board with an on board cpu, the L2 Cache is gold topped as well as the sun Sparc chip. Although the gold glaze on the cpu doesn't appear very thick, the rest of the board is chock full along with a couple gold finger edges.
Just wondering if it goes anywhere other than large socket. Th board weighs in at 1.5 lbs alone LOL.. Or as you see it
File comment: Depth of the ICs
File comment: Dimm gold connectors look fat
File comment: Sun SBUS card connector
File comment: Bottom monolithic is its middle name
File comment: Top
PostPosted: Wed Mar 25, 2015 4:25 pm
You should be able to get gold cap chip board grade for that.
PostPosted: Wed Mar 25, 2015 6:27 pm
I wonder if you removed the three processors if the board would fetch for Telecom and get paid for the processors separately.
PostPosted: Wed Mar 25, 2015 7:28 pm
Thanks guys!
Well the CPU is soldered on, I should take a pic of that closer, it has two large bolts extruding from the top. Like Frankenstein's head, I've thought about taking a heat gun to it and making a belt buckle out of the CPU.
LOL!
I'll post an image of the CPU when I get home.
