It is currently Fri Nov 06, 2026 4:42 pm
 Post subject: Help grade Pete
PostPosted: Wed Jul 15, 2020 9:01 pm
1. C had gold fingers cut off
4. B the green fiber if that is what it was is partially removed.
 Post subject: Re: Help grade Pete
PostPosted: Sun Jul 19, 2020 1:35 pm
A)peripheral
b)midgrade
c)peripheral
A)peripheral
b)peripheral
c)peripheral
A)peripheral
b)peripheral
A)peripheral (just barely. One more thing missing it would be mid or low)
b)peripheral
c)peripheral
PostPosted: Sun Jul 19, 2020 1:49 pm
Thank you for the help.
And can you explain why 3 c is a mid grade. I’ve been told if it has gold corner chip it’s at least a peripheral. Not being an ass. Just trying to learn. These get confusing. And I really appreciate the help. I’m very thankful for this forum.
PostPosted: Sun Jul 19, 2020 1:58 pm
1b)
Because initially I didn’t even see the chip. It’s missing most of the carrier.
This is a harvested:damaged board.
Chris has set it up that damaged/harvests boards will immediately downgrade.
Sometimes I make a judgement call and declare a damaged board worth a higher review. Here there’s nothing to save the board. The full controller is the only thing that could have bumped it to peripheral. All that’s left is a the core die and a few etches for ball connectors.
3 down from the top doesn’t have a C
PostPosted: Sun Jul 19, 2020 2:03 pm
I found your question board. And changed it.
This is why I suggest making more posts. One set of front and back per post.
Scrolling up and down while flipping back and forth two type grades let’s in occasional mistakes
PostPosted: Sun Jul 19, 2020 2:04 pm
It’s third from bottom. In the comment I marked it 3
PostPosted: Sun Jul 19, 2020 2:07 pm
Oh ok. I will post like you suggest. I thought if I did I would be upsetting people if I posted to many. Thanks man
PostPosted: Sun Jul 19, 2020 3:12 pm
Nah. Make as many new threads as you have need for.
Besides 20 threads of 3-6 boards is much easier for everyone to follow over 3-6 threads of 20 boards.
