 Post subject: Grade please a3
PostPosted: Mon Jul 20, 2020 2:00 pm
C. Top, bottom with black plastic. Bottom without black plastic
 Post subject: Re: Grade please a3
PostPosted: Mon Jul 20, 2020 2:14 pm
Assuming missing letters :
A midgrade (peripheral if gold connectors)
B midgrade
C peripheral, barely
D backplane
E peripheral
F if pins are gold Apple cpu. If not pinless.
G low or mid.
PostPosted: Mon Jul 20, 2020 2:32 pm
C is three piece. I took the black plastic off one.
PostPosted: Mon Jul 20, 2020 2:34 pm
F. The pins are gold. Wow I have a lot of those to!
PostPosted: Mon Jul 20, 2020 2:37 pm
Close up of A
PostPosted: Mon Jul 20, 2020 3:32 pm
Yes. I know the design. It’s just barely peripheral
PostPosted: Mon Jul 20, 2020 3:41 pm
I’m fairly sure these will just clear apple cpu. Which by technical term is a processor direct socket (PDS) and its variations. However worst case this would still likely be a trimmed slot processor which is literally what it is. A full processor package with pins instead of edge (finger) connectors.
This is a fairly low end implementation. Apple uses between 28-69 pins or 125. HP used 240. Atom boards have a few hundred as do high end PI risers. All of which go as Apple cpu.
It’s a borderline piece but I THINK it clears.
PostPosted: Mon Jul 20, 2020 3:47 pm
Dude. You’ve seen it all. Impressive
PostPosted: Mon Jul 20, 2020 4:05 pm
C) It’s a quick change riser for a network relay. When one failed change them all. Quick simple fixed cost repair. A bit wasteful but understandable.
F) more common than you’d think. I just take a lot of stuff apart to see how it works. Pre-Intel Macs are the most obvious supply but laser printers and office copiers use them too. A/V equipment...! There’s a fine line between being a processor riser and a processor card I don’t think anyone agrees on... but generally speaking it’s a basic premise many have tried over the years.
