It is currently Sat Sep 19, 2026 2:27 am
 Post subject: Solder samples?
PostPosted: Sat Mar 01, 2014 12:28 am
I was told that these were solder samples.
Not populated at all.
When the "solder mask" is removed - the entire surface of the boards is gold.
Both faces........
If you need more info to price these let me know.
I put the Pentium Chip there for some size comparison.
5 boards in each "sheet". 10 1/2 inches long 1 1/4 wide.
Thanks for your time. And thank you for a great site.
 Post subject: Re: Solder samples?
PostPosted: Mon Mar 03, 2014 4:38 pm
It was a pleasure speaking with you on the phone.
As I mentioned then, I would need to see a sample of these boards before I could make you a "fair" offer. Due to the unknown nature of the coating, you would likely not be satisfied with the low price I would have to offer you otherwise.
However, if I were to be able to shoot it with our XRF gun, we would have a better idea of the nature of that coating and have a more accurate idea as to the value.
That is the trouble with odd-ball items such as these blanks. There is simply not enough data about them to make a reasonable offer, unlike the more traditional items like motherboards and standard CPU's where the values are gospel.
PostPosted: Tue Mar 04, 2014 2:38 am
Thank you Chris.
Totally understandable. The honesty is appreciated.
Lots to learn in this business.
GF
PostPosted: Thu Mar 20, 2014 8:42 pm
i would try ebay
