It is currently Sun Aug 30, 2026 11:08 am
 Post subject: Boards to grade (3)
PostPosted: Mon Aug 03, 2020 2:22 pm
Please help me grade these boards
 Post subject: Re: Boards to grade (3)
PostPosted: Tue Aug 04, 2020 12:13 am
1/2 -peripheral board, Remove the bulky heat spreaders (heat sinks)
3- low grade board, *you could remove the bigger ICs and keep same grade* ICs would go as IC category
4 - low grade board, Try to remove the Aluminum heat spreaders, they're pretty bulky; they're only attached by little tabs you can put a flat head behind and pry off
PostPosted: Fri Aug 07, 2020 8:03 pm
:thumbsup:
