 Post subject: Question
PostPosted: Tue Aug 04, 2020 2:16 pm
What are these little guys? Are they worth anything?
Thanks so much!
Lynne
 Post subject: Re: Question
PostPosted: Tue Aug 04, 2020 2:57 pm
Those are gold surface mount high temp resistors.
*** Yes, they are gold but IF you do not depopulate/harvest boards and do not have high quantity in excess, DO NOT remove components.
Unless you're harvesting hundreds to thousands of pounds, it's not worth your time, effort, and payout. You'll have to have a buyer and refiner as well. ***
PostPosted: Fri Aug 07, 2020 8:18 pm
:thumbsup:
Exactly. Two don’t weigh anything. 20 don’t weigh enough for Chris to buy them alone.
If you have 200+ (weight helps here) you’ll move into the realm of a few dollars or so per pound.
PostPosted: Sat Aug 08, 2020 9:39 am
Would that board go as gold cap chip board?
I know without seeing the entire board an answer to that may not be possible.
PostPosted: Sat Aug 08, 2020 11:29 am
I posted a picture of the whole board, back and front, and Lost said mid grade. It's a few posts down from this one and the round board has a sharpie propping it up. Nice pins on the back. Thanks for your comment.
Thanks so much!
Lynne
PostPosted: Sat Aug 08, 2020 1:56 pm
Bump that thread for me to take a second look at it just to be sure.
PostPosted: Sat Aug 08, 2020 1:58 pm
Never mind I found it. Definitely midgrade. Cut the pins.
Those guys are so small I didn’t even see them at first.
