It is currently Thu Sep 10, 2026 4:25 pm
PostPosted: Sat Aug 08, 2020 4:06 am
There's nothing wrong in removing components to increase your dollar payout... but...
...you have a lot of factors to consider!
Time/effort in removing what you want compared to payout , as is.
quantity, quantity, quantity, takes a bunch to make that extra bunch.
Buyer/refiner and meeting quotas/deadlines to initiate the refine or send in.
Having the space to hold all the extra components and categorize or separate materials.
Finding a buyer for those depopulated and harvested boards that will match a decent rate instead of heavy discounting.
Hazardous materials and dangerous fumes from heat gun or refining chemicals
Patience and tedious operations
I myself harvest and depopulate many boards only ranging from the high grade materials, where you would get biggest bang for buck, per say.
but...
I also take a big cut if I just left as is. Do I make more in the long run? Yes. I do spend more time in removing and preparing each n every board though; which takes more turn around time for my turn ins to get paid. It took me a few years to educate myself in what components were, what precious metal type, and to find solutions in removing each component and prepare it. My working hours and duration on each board are much greater than the average "e-waster" because I have to analyze the board more. Once you get the hang of things and comfortable in doing what you want to prepare, you'll find the materials "worth-while" and the others you send down the line to the big foundry to do, get your money n call it a day ones. Brown and mid grade boards are reasonable to down grade because, mostly, they can't go any lower. If I were to promote harvesting boards, I would agree on using your heat gun or air chisel/flat head to pop off the larger ICs.
But then again...
Is it worth it? If you don't have hundreds to thousands of lbs even in just brown or mid grade boards and you're pulling off extra ICs and packages when you only accumulate roughly hundred or less lbs yearly; I would say move on and don't waste your time. Drop your material and move on to the next turn in. " dime is holding up a dollar" Even harvesting high dollar boards and grabbing the expensive ICs, MLCCS, tant caps, gold/silver oscillators, gold resistors, or even cutting fingers to get that "high rate", if you have no quantity, you just lost money in the board you depopulated and have barely any weight in what you harvested in high dollar category; literally you lose money by thinking you're making more in collecting and harvesting the high dollar materials, decreasing its' value.
As in my case, I withhold thousands of lbs monthly and take the extra time to depopulate what in my opinion is worth it or what in market value is high at the time. I can accumulate the extra quantities in the higher paying rates from depopulating boards. One thing you can happily bogart are CPU and processors. Easily removable socket to get the higher rate, obviously doesn't downgrade your board. Removable/socket ICs sometimes are 50/50, they can occasionally help upgrade your board if left in but also can be removed for a higher IC rate and the board remain in a good payout rate. Keep your ram and turn in separate, same goes for gold finger cards. Cutting fingers really isn't worth the money or time unless you have thousands of cards or memory sticks. Then again you have to find a refiner, try killing yourself to get the extra doe, or lose everything you harvested because you don't know how to correctly refine it yet; ruining everything you just did(losing money).
Like Chris mentioned, pulling off BGAs, and gold cornered flatpacks; yah you get a nice $15.00 per lb rate but if you only receive or purchase 20 lbs of motherboards and take those all off the boards, you would have 20lbs of low grade mother boards with MAYBE a lb or two of BGAs, equivalent to the same payout as just turning in the non-harvested mother boards!
I acquire hundreds of lbs of cell phones, the time and effort to take every single one apart to get that cell phone board rate would take me FOREVER. Not to mention, hazmat batteries if swollen, I have to pay and dispose of now, plastic waste to recycle and correctly dispose of, lcd screens etc etc.
There's many things just better off left as is.
All in all I just wanted to brush on this topic and give a little insight to the new e-scrappers out there. What you think will be making you extra money might not be what you're expecting.
PostPosted: Sat Aug 08, 2020 4:34 am
Any questions in regarding if it's worth pulling something off or devaluing a board to maybe increase your profit, ask first.
PostPosted: Sat Aug 08, 2020 2:35 pm
Great write up!
Absolutely agree.
To put this in. Much higher example:
Manually Removing flat packs from 1000 pounds of motherboards won’t be worth it. For most people. If you’re going to depop you need to do so completely to make money.
Keep in mind refineries that do complete recovery use automated hot air reflow removal. Computer imaging to auto-sort removed components from the (dis)assembly line.
Massive scale. 10s of thousands of pounds per day.
Again removing gold tabs or gold fingers from a thousand pounds boards is barely past break even. If you have enough and recover everything and sell it all, you’ll make more with depop
Just don’t expect Chris or most any yard to be interested in your blanks. Which leaves you on the hook to get rid of them responsibly. There’s buyers... but they want 50,000 pounds a shipment. A trailer load. Much less than that you’ll probably be paying to get rid of them.
PostPosted: Wed Aug 12, 2020 8:50 pm
I've been there and done this before.
My personal takeaway: the only things you should depopulate from a board are ceramic IC's (or IC's in general) because they are easy to incinerate at the refinery, or 8086/CPU's.
You're wasting your time harvesting crystal oscillators, tantalum capacitors, etc.
If you are backyard refining, then godspeed.
However, if youre sending boards in here to Boardsort, or sending them in quantity to a refiner, leave that stuff on. And move on.
PostPosted: Wed Oct 14, 2020 10:02 pm
Sorry if this is a question that's been answered elsewhere (I did try searching).
I'm curious - what about removing components / sections of boards to increase the value of the board itself? For example, I've come across some that are clearly midgrade, but if a portion of the board that contained all the "dead weight" like can capacitors, transformers, and base metal heatsinks that protect mosfets / transistors was removed they would resemble peripheral boards. I get a lot of these - one client of mine repairs janitorial equipment, and I'd love to be able to process his boards to a better pay grade.
Using the example of midgrade provided by boardsort (linked below for convenience), if the transformers, large capacitors, and transistors were removed would it qualify as peripheral, or would there be too much blank space? I've been told it's possible to remove, say, a lone transformer to bump some peripheral boards up to low telco, etc., but I think what I'm describing is a step above that.
off site link
PostPosted: Thu Oct 15, 2020 4:11 am
Using the midgrade board posted in the payout rates chart:
If you were to cleanly cut just the lower right corner of ICs from the rest of the board that section would go as peripheral.
But that’s a specific case.
There’s more than ICs that make a board peripheral and how the board is made is a big part of that.
Grossly simplifying requirements;
Brown boards rarely have a Center “sandwich” layer. Often instead using surface layer etching.
and single sided boards usually follow that method as well
To make peripheral+ (excluding extreme exceptions) a board must have 4 or more layers, 3 of which are copper or better.
The substrate. X2
surface layer and a centre layer
PostPosted: Thu Oct 15, 2020 11:42 am
Thanks much, Lost. I figured it would be more complicated than just lowering the junk:IC chip ratio.
PostPosted: Thu Oct 15, 2020 2:58 pm
I could write a book on the phone and email discussions I’ve had with Chris and with other companies over the what and how of technology and pricing.
I’m the first to admit I’m not always right.
And we don’t always agree. But he’s the company and I’m just a user. His word is final. Disagreements don’t mean I don’t understand though. And with minor explanation I often understand before he finishes why he makes his decisions.
There’s a lot of thought that must go into the top end of the recycling pyramid.
A classing mistake of one board is an oops. Misclassing 10,000 lbs makes a major flux in accounting!
The classes are guides. Everything is (within reason) debatable.
