It is currently Sun Aug 30, 2026 1:22 pm
 Post subject: Boards for Grading
PostPosted: Sat Aug 08, 2020 8:26 pm
Please help me grade these boards.
 Post subject: Re: Boards for Grading
PostPosted: Sat Aug 08, 2020 10:12 pm
Midgrade
Midgrade
Cd/dvd
Peripheral
PostPosted: Sun Aug 09, 2020 10:35 pm
I was wondering why the last board in this post was graded as peripheral. I would think that it would be midgrade.
PostPosted: Mon Aug 10, 2020 12:34 am
Because it’s borderline and at one point Chris had sad if you”see RCA” to consider it peripheral. I’ll go with that here since we have not only the ICs but two silver switches, gold plated jacks, and a gold pin audio 3.5 p port.
On a person opinion I’d knock the copper coil off just to be sure.
PostPosted: Mon Aug 10, 2020 10:19 am
Thanks for letting me know!
PostPosted: Mon Aug 10, 2020 6:24 pm
Should I just take a pair of pliers and twist it off (carefully of course). I don't want to accidentally damage/devalue the overall board.
Any other suggestions?
PostPosted: Wed Aug 12, 2020 6:19 pm
Gently twist and pull up. Then snip. Copper so soft. Decent pair of scissors can cut through eventually
PostPosted: Thu Aug 13, 2020 11:57 am
Thanks, that worked well and was easy to do.
As a general rule is it ok to remove Inductors? Or will that harm the overall grade of a board?
PostPosted: Thu Aug 13, 2020 1:38 pm
You won’t hurt the grade if it’s obvious what it was.
Generally though don’t remove anything without being told to. I. Quick eye scanning as boards are weighed many times there’s not enough focus to see what was removed. So an obviously modified board with a missing component could be knocked out to midgrade even if it was a transformer that was removed.
