It is currently Sun Aug 30, 2026 12:27 pm
 Post subject: More id help please
PostPosted: Sat Aug 15, 2020 3:46 pm
here is 5 more boards for id also I have 1 question
1) if a board is graded gold finger . Do i need to take stuff off or just send in as is. Thanks for your help.
 Post subject: Re: More id help please
PostPosted: Sun Aug 16, 2020 10:02 pm
1)Peripheral
2)midgrade
3)Low grade gold finger card
4)Gold finger card
5)Peripheral (possible higher)
PostPosted: Mon Aug 17, 2020 1:43 am
3 is a wierd one..are they two boards joined buy pin brige? or what..
PostPosted: Mon Aug 17, 2020 3:08 am
Yep. Like IBM dell has some proprietary crap that is non-spec
Notice two extra gold pins on the board connector? (On the fingers) They offset a port slightly. That way they save money using a single port and a splitter board with two extra power connectors on the mobo socket. The slightly smaller non-atx board board no longer requires licensing since it’s ATX compatible. Not ATX.
IBM, and VIA, both do the same thing.
The board itself is a passive pass through. The only “active” aspect being a risc controller that puts both sockets on opposite cycles of the cpu clock: up and down.
It’s basically Dell’s implementation of a method Woz came up with in 79!
Works great at 16MHz. Not so well at 3+GHz!
PostPosted: Mon Aug 17, 2020 11:05 am
Send in as is
PostPosted: Mon Aug 17, 2020 7:08 pm
Thank you everyone
PostPosted: Mon Aug 17, 2020 7:14 pm
Thank you everyone
