It is currently Thu Aug 06, 2026 5:22 am
PostPosted: Fri Aug 28, 2020 10:04 pm
Hi,
Sorry, I've been going through motherboards and circuit boards for a couple of hours now. I've got these CPUs, but couldn't match them up the pictures. Could you please identify, so I can send this stuff off?
Also, I have a couple of power supply boards. Do you take those? I've attached photos.
PostPosted: Sat Aug 29, 2020 1:00 am
Those PSU boards would be low grade.
I do this to all PSU units.
I pull off the larger heat spreaders and throw in AL and cut wire ; which looks like you have. And if you're an extra mileage guy, pull 1 IC off each individual, no need to go for more; it adds to IC collection.
CPUs with heat sink top and pins, green fiber with metal
CPUs with no heat sink top, w/ pins, green/brown no metal
CPUs heat sink top, pin less(dots), no pin CPU
PostPosted: Sat Aug 29, 2020 1:03 am
The power supply boards are low grade.
They’re all green CPUs so this is quick.
no pins... pinless
Pins and metal top... green fibre with metal
Pins and not metal... green fibre
PostPosted: Sun Aug 30, 2020 3:15 pm
Great replies! thanks so much, that cleared it up for me.
