It is currently Thu Apr 30, 2026 6:04 pm
 Post subject: Board with Removable IC
PostPosted: Sat Aug 29, 2020 10:20 am
Looking for advice on what I should do with the board below? The IC is in a socket and is removable.
PostPosted: Sat Aug 29, 2020 11:56 am
The board is low grade and no possibility of upgrade.
Remove the IC and keep for your IC collection.
PostPosted: Sat Aug 29, 2020 12:01 pm
On any removable IC like this one, if they don't pull out with your fingers, a small, longer flat head screwdriver slides right under the whole thing and pop up.
PostPosted: Sat Aug 29, 2020 1:03 pm
Remove the IC carefully. If you know what the item was a rom for it could be a quick auction flip for you.
PostPosted: Sat Aug 29, 2020 1:45 pm
Thanks for the fast response and the tip about auctioning it. I'll look into that.
PostPosted: Sat Aug 29, 2020 1:51 pm
It’s from sharper image. A known brand, and generally over priced expensive when new.
Given it’s low grade is pop the Tom and sell the rom and board separately.
PostPosted: Sat Aug 29, 2020 2:11 pm
You're correct, it was from an Ionic Breeze machine. Is there a market for used boards like this, even with the cut wires? Also any thoughts on the best places to sell these types of items? eBay? Craigslist? others?
PostPosted: Sat Aug 29, 2020 4:03 pm
The board isn’t going to get much with or without wires. But a known and limited supply board will always fetch a few bucks eventually.
SI roms, socketed roms in general, are fairly easy to sell. Just protect the pins when you ship it.
Ebay works well with non-computer roms if you cross post them in industrial along with the parts category for the class of device it’s from.
You’ll find a large supply of IDKWTFII parts under that category.
But targeted sales work even better. NewEgg is a great site to third party sell at if you jump through the hoops to get there.
It’s been a while since I’ve used it but tiger direct had a nice 3rd party service as well.
Tagging the title with sharper image rom SI
Is a good start for ebay.
The actual item number for the other two sites.
Sharper image rom #nnnnn
PostPosted: Sat Aug 29, 2020 4:12 pm
Thanks lost! This is a wealth of useful information.
I'll look into these options, and even if it just a few dollars, that is better than the few cents that I would get from scrapping it (and reuse is the better than recycling!)
PostPosted: Sat Aug 29, 2020 4:55 pm
Bob = non
Edited
