It is currently Wed May 06, 2026 4:29 am
 Post subject: PCB ID
PostPosted: Sat Aug 29, 2020 10:20 pm
Please help ID these PCBs. Thanks!
 Post subject: Re: PCB ID
PostPosted: Mon Aug 31, 2020 2:41 am
Naughty user! Be back later.
PostPosted: Mon Aug 31, 2020 2:21 pm
1 low grade
2 mid
3 low
4 low
5 note
6 low grade gold finger card
7 low grade
8 mid
9 peripheral
5, as is midgrade. If you remove the screen the underlying board as a whole may or may not make peripheral. Since boardsort doesn’t buy the screen and generally asks you remove them if possible it’s a risk. This on I believe is glued to the board.
PostPosted: Mon Aug 31, 2020 10:38 pm
Thanks Lost. Apologies for exceeding the board limit on a couple of these.
I'll try and remove the screen and upload a new picture.
PostPosted: Fri Sep 04, 2020 4:23 pm
The screen was actually snapped in so it came off pretty clean.
PostPosted: Fri Sep 04, 2020 5:03 pm
That should be peripheral.
PostPosted: Fri Sep 04, 2020 8:31 pm
Yep
PostPosted: Mon Sep 07, 2020 12:41 pm
Great, thanks guys.
I have two follow up questions:
1. Is it just a general rule that LCD screens should be removed? If so, does this even apply to low grade boards?
2. Number 6 was graded as "low grade gold finger card". Is there anything that I can remove to make it a regular gold finger card? I attached close up pictures.
PostPosted: Thu Sep 10, 2020 2:47 am
6, **carefully ** remove the shield.
You'll upgrade to GFC or low/high telco
PostPosted: Thu Sep 10, 2020 5:13 pm
Shields off clean gold finger card
Shields on low gold finger
