It is currently Thu Nov 05, 2026 11:58 am
 Post subject: Transitors help
PostPosted: Sat Sep 12, 2020 12:08 am
Hi all,
I'm wondering if these older, larger transistors contain anything worth saving. I searched and searched part numbers and descriptions - I'm fairly certain they're transistors (they came out of older radios), but I've only successfully searched one part number out, which listed it at a transistor. They were all mounted on large aluminum sinks.
Unlike what I typically call to mind as transistors, these have many legs and multiple visible bonding wires. If I recall correctly, they all came from Sony devices.
I've included some USB microscope pictures that appear to confirm what they naked eye seems to show - that there is some precious metal content in these. I haven't done an acid test to verify any of the metals present, and to be honest, I suspect the gold color might be due to an overlay of materials or some other trick of the eye.
Does anyone have any experience with these? Am I looking at gold plate or braising or something less? I typically grab transistors (the tripod-legged, copper-backed ones) off low-grade boards, but these stand out.
I'll post one good example, but I've got a coffee can full of this type of component of various sizes. All show similar teensy amounts gold-appearing material when the plastic covers are knocked off. My main question is, are they worth more than the #2 copper bin I plan to throw them in - or should I send them to Boardsort as a grade of some kind of board?
I apologize in advance for my lack of knowledge here.
 Post subject: Re: Transitors help
PostPosted: Sat Sep 12, 2020 2:16 am
If you post model numbers, part numbers or the like there’s a 90%+ chance I can track it down in a few days or so. I have a massive parts database.
Depending on the age it’s not all that unlikely to find gold.
