 Post subject: Please ID Group#2
PostPosted: Wed Sep 23, 2020 2:19 pm
Please ID Category. Board from Sony disc drive
File comment: Front/Back
 Post subject: Re: Please ID Group#2
PostPosted: Fri Sep 25, 2020 2:13 am
Floppy disk controller board
Peripheral
PostPosted: Tue Nov 22, 2022 10:14 pm
Peripheral
Is it considered low peripheral or high peripheral?
PostPosted: Tue Nov 22, 2022 10:32 pm
If pins are gold, high peripheral; if not, midgrade, possibly low peripheral.
PostPosted: Wed Nov 23, 2022 12:07 am
If the pins are not gold I would expect low peripheral to be the class.
PostPosted: Wed Nov 23, 2022 9:01 pm
I wasn't completely sure so I said the lower of the two grades that they might fall under. At least before the split I think they went either low grade or midgrade.
PostPosted: Thu Nov 24, 2022 7:05 am
It’s good thinking.
The thing with floppy boards is the main 5 types of disk drive are fairly consistent. You have your single layer or dual layer controller chip, a few ASICs and the thick plate pins, or edge connector (gold fingers).
The value is nearly the same be it an 8” drive or a 3” drive.
About the only exception tin pins, and tin is expensive enough to guarantee you still get some level of peripheral.
