It is currently Tue Sep 15, 2026 3:37 pm
PostPosted: Thu Sep 24, 2020 4:20 pm
I got a few boxes of these CD drives. My question is are they worth anything? Do they have to be taken apart or will you buy them as is? TIA
PostPosted: Thu Sep 24, 2020 5:20 pm
Boardsort will buy as is for 0.15 per lb. If you brake it apart the board is a CD-ROM board at $4.25 per lb. Part of the casing is aluminum. So it depends if you are In it for the quick nickel or for the slow dime.
PostPosted: Fri Sep 25, 2020 1:52 am
If you didn’t start scraping
The 10n can be cross flashed with LGs wn14 firmware. Making a rather low end laptop drive capable of 32-40x dvd read spreads in an external slim caddy.
Depending on the exact revision If you’re willing to pick up a dell SATA or mSATA to usb adaptor you can flash these in about 30 second each and flip them for $10-$25 on ebay or drive swap sites.
Take a look for your model at doom9 before you junk them.
If you have Windows and any cd or dvd disc.
Nero offers a free disc check program
Which works fine on Linux with wine
And on MacOS with PlayOnMac.
Or you can git/make NeroDC on any posix system including windows PowerShell.
Then just pop in a disc and run a 10 second drive test!
This is a cast-off junk drive from MEJ but it’s also extremely popular, along with the 8 and 12 versions, with small film distributors like shriek show, KOTW, etc for use in slim drive towers. There’s no lockout in the base rom so with a firmware patch you can set read speeds to psycho levels.
This was the exact drive I used to make a CD gun for a friend’s post-grad project. Setting the drive to 500x and a guided steal duct to let the discs fly out. :)*
More realistically once patched these can read competently at around 22-26x in a drive tower with a small enough shell and kernel and enough ram. Making them one of the few junk drives to still command above BDRom drive prices.
