It is currently Sun Aug 02, 2026 10:32 am
 Post subject: What Is This? Hardrive?
PostPosted: Wed Sep 30, 2020 3:09 pm
i had a customer drop me off 16 cases (1,565ish) of these i have no clue what they are nor how to classify them any help would be good, housing is metal but the inside is, well see the pics, the person who dropped them off said they were hard drives but idk
PostPosted: Wed Sep 30, 2020 5:23 pm
I think that's going to be a custom quote item, is it possible (or practical) to remove that "board" thing from the housing intact? If not it might wind up a peripheral or similar rate (attached to the metal)
Representin otown, central FL
PostPosted: Wed Sep 30, 2020 6:48 pm
no, tried its WELL glued to the bottom i tried to take a chisel/knife with no luck on removing the board
PostPosted: Thu Oct 01, 2020 11:51 am
Try boiling them, sounds wierd but it works for some other things that are glued real hard, just don't use whatever pot you boiled them in for food again
PostPosted: Thu Oct 01, 2020 12:15 pm
I’m not positive but yes it does look like storage cubes.
I’m trying to match up one of the numbers on the drive as i type.
If you do boil make sure there’s no glass on that board first.
PostPosted: Thu Oct 01, 2020 12:29 pm
Be careful using a knife, chisel, cutting or prying methods on these boards. The inside has a lot of nice material, just be careful of not damaging it , trying things like that.
Boiling or using low heat should detach it. You can also try popping out all those nods in the metal the board attaches to and using them to try and peel back the board off the metal.
Another thing, if the metal casing is double ply or has another layer, separate them. They can be stainless and the other nickel. That would be a good payout if so. You'll have to test one for nickel. Plus, maybe you could heat the outside to peel the board or better see how it adheres.
PostPosted: Thu Oct 01, 2020 1:16 pm
i will try Boiling but the volume I have... each unit is sealed.... here is a side view of the item, i cut the item in 1/2 in the middle looks like the board is connected/glued right to the housing of the sealed unit, i tried to google the numbers, no luck, the number on the back is different to each unit, its not double ply metal is solid top and bottom.
PostPosted: Sat Oct 03, 2020 7:45 pm
Yep. Look like aero or defence units.
Whatever it is was not ever listed publicly. My database comes up empty though I find some cross-references.
I’ll forward this to Chris and let him reply.
I’ve seen similar boxes in aerospace and nautical. And in commercial IT/Electrical.
PostPosted: Sun Oct 04, 2020 11:14 am
thank you for the reply i cant cross reference anything on this either no numbers inside, or outside that help so at least we are on the same page as that, LoL, thank you i look forward to hearing from Chris,
PostPosted: Mon Oct 05, 2020 1:34 pm
One of the numbers come up as the shell design.
Hence cross reference. But it’s a reference point for A case, not THE case.
Whatever it is it’s BTO.
Chris will be by soon to give a better reply as to what it’s worth.
