It is currently Sat Nov 07, 2026 12:34 pm
 Post subject: mother boards and wire.
PostPosted: Sat Mar 22, 2014 5:02 pm
OK so of course no ram or processor, so anything else I should rake of these boards to get the most from board sort. Also the fan should I just cut the wire and toss the fan. Other one is a drive wire how should I handle that.
PostPosted: Sat Mar 22, 2014 5:49 pm
Those are both small socket motherboards, the hard drive cable just pulls off of the board, the fan wire will just pull off too. Just make sure all the aluminum/copper heatsinks are off the board and it's good to go.
PostPosted: Sat Mar 22, 2014 7:11 pm
as scob89 says, pull the drive cables and strip the heatsinks off the boards, but what I would do is trim the cable ends off the drive cables and sell them as cable ends, and the cables can go with mixed wire. Toss the fan with your transformers/CBMs. That should give you max value for your scrap.
