It is currently Sun Nov 08, 2026 3:51 am
PostPosted: Wed Nov 11, 2020 4:56 pm
I'm trying to check what I have, three different boards, thank you for your help!
PostPosted: Wed Nov 11, 2020 7:16 pm
Looks like backplane.
Backplane uses a standardised set of pins for connectors.
Vs
Pin board tends to be used for BTO and prototype use with thicker heavier high grade pins.
Vs
Wire wrap pin board is a major jump again with much thicker GM or RG thickness level plating and longer and thicker still pins for wrapping wire ends.
