It is currently Mon Aug 31, 2026 2:36 am
 Post subject: cpu grading
PostPosted: Tue Oct 13, 2020 1:23 pm
please check if this grading is correct?
-the 7 cpu with no pins are: No Pin CPU @ $5.45?
-the 7 cpu with pins are: P4/Green Fiber With Metal @ $8.05?
-what about the two large cpu with heatsinks on them?
 Post subject: Re: cpu grading
PostPosted: Tue Oct 13, 2020 2:04 pm
You are correct.
The two CPU's with the heat sinks on them might get the 386\486 grade if you're able to separate them. Lostinlodos will give you some advice on how to separate them.
PostPosted: Wed Oct 14, 2020 2:27 pm
The first pic looks like an overdrive and a coproc.
With the tops off they’ll likely be 486
PostPosted: Thu Nov 12, 2020 10:28 pm
so I was able to get the heatsinks off, are these a better grade now?
PostPosted: Fri Nov 13, 2020 12:17 am
I can’t match the IDs by phone and am not infront of my computer.
So I’m going on a limb.
I’ll stick with my call. Looks like a P5 transitional era overdrive and a coproc.
Staying with 386/486.
For both.
Double down, all in, and final answer.
