The small konica board is missing it’s connectors. And is now firmly low telco. The larger board, I’m trying to recall but believe you cut out the flash sockets. As it is looks to be just barely low telco.
These two aside you’re in a grey area overall.
Officially the answer is removing ICs including flatpacks makes midgrade. My generation of that extends to removing gold pin connectors. Ion paper (or text here) no one should remove anything that i or a member of boardsort hasn’t specifically said to remove. That said I myself pull components. Mostly capacitors, fuses, resistors. But I have multiple decades of dealing with both board work and scrap. And have a good idea what makes what valuable.
So What you stated you removed is not going to cause you any issue. But Removing a flash card adapter is a nono. You got by with it here. They’re technically dual inline pin components but are not considered dip sockets. Even removing actual dip sockets, 4-30 pins in 2-16 pin rows, is not wise. Especially when you can get a box of 25 new for $5 for the higher quality ones.
I have two suggestions here. One, contact Chris by email or phone AFTER thanksgiving. He’s really down to earth. And it’s hard to find higher ups in any field who love what they do like Chris does. Explain exactly what you removed and how much of this stuff you have. That way he’s aware of who you are and what you’re sending long before it gets there and causes confusion. Second post pictures like you did here, of anything questionable and all boards with any major missing piece or cutouts. It will let one of us longer term users review things up front. Making less commotion in shipments and giving you some fall back with Chris in ‘I did my homework’ down the line if someone at the dock someday decides to ignore a batch or box as harvested midgrade. Not likely but it /does/ happen from time to time. Everyone has bad days where they say FI.
By doing both you make sure things go smoothly.
_________________ 42 6F 61 72 64 73 6F 72 74 2E 63 6F 6D
