It is currently Sat Nov 07, 2026 6:06 am
 Post subject: Single chip cpu boards
PostPosted: Mon Nov 30, 2020 12:00 pm
I have around fifteen identical boards from some security system’s remote controlled outlet modules. I would normally throw these in low grade but its to my understanding that the chips on these are some sort of 4 bit cpu. Anyone know if that could lift them into a higher grade than low?
PostPosted: Mon Nov 30, 2020 12:58 pm
I would think those would go as Midgrade.
PostPosted: Wed Dec 02, 2020 1:21 am
Try removing one of those chips and weigh the difference between it being on and off the board.
Might do better selling boards as low and separating the IC, to sell as, IC class.
PostPosted: Wed Dec 02, 2020 2:58 pm
If the chips /are/ worth more alone those boards are easy to snap by hand.
Quick etch with a box cutter or knife on both sides of the chip pins they snap really nicely
PostPosted: Wed Dec 02, 2020 9:44 pm
I just removed the chips and put em in the ic pile,I weighed them and indeed they are worth more as ics and low separate. Thanks for the insight all
