It is currently Mon Aug 31, 2026 3:44 am
PostPosted: Wed Dec 02, 2020 4:15 pm
#1 peripheral
#2 peripheral
#3 peripheral, three socketed Ic's
#4 peripheral
#5 peripheral
#6 peripheral
#7 peripheral, Do i need to remove the screen
#8 peripheral, maybe Telco if i remove the screen?
PostPosted: Fri Dec 04, 2020 4:27 pm
do i need to remove the Screens on #7 &8 or just tape them up?
can i remove the socketed chips on #3 with out a downgrade?
PostPosted: Fri Dec 04, 2020 5:05 pm
1 peripheral
2 peripheral
3 peripheral as shown. Midgrade without ICs
4 peripheral
5 peripheral
6 midgrade
7 peripheral tape over scree
8 snap/cut off screen for low telco
Generally you should remove any screen that can be safely removed. 7 has two rows of pins, and is not easily removable. Also it is flat so taping over it should keep everyone safe.
8, the vertical screen can be easily removed by cutting or snapping the board. It is unsafe(ish) to ship as is so ideally remove it.
If you absolutely can not remove it it would be peripheral as is.
PostPosted: Fri Dec 04, 2020 5:43 pm
Thanks
