TLDR: most were gone by the mid 2000s.
Different by manufacturer. And phased out doesn’t mean not made. Nor are all new cpus non-ceramic.
Intel left the market with the core line. The P3 being the end of the line for x86 ceramics. Ceramic 960s were made as late as the mid 2000s.
AMD left x86 ceramics with the K6-2 and Athlon. But still makes a risc chip, the 38nn series, in ceramic package for industrial use. Some ARM ceramics are still made too: all SM BGA chips.
Apple switched to fibre mid-line in the Power era. I doubt anyone knows exactly when. I’ve found ceramic boards in G5s. And fibre in the original. General consensus is G4 was the end of ceramic use to any degree. Probably to use up ceramic packages that matched size wise three generations. But Power 6 and 7 has ceramic varieties. So it was apple’s supply line that moved, not Motorola/IBM.
Nintendo used ceramics as late as the Game Cube.
Sega used ceramics in the DreamCast and still uses them in arcade boards in the M line. The M and AM chips simply can not be cooled properly in fibre. The design, dating to 1994, is one of the early 3D stacked packages and generally requires a ceramic package for passive copper cooling.
Texas Instruments used a ceramic risc chip as late as the TI99 and Explorer line of super calculators.
Not to mention:
As far as I’m aware ALL 256-bit and MOST 128-bit extensions to x86 code are in ceramic packages. This includes the ultra über HP security laptop (running HP-X), and the Falcon 9, running a custom BSD. So they’re not dead. As much as rarely used. I know Apple killed ceramics for all NEW cards with the original “Lux” modern iMac. Cooling issues. Placing the mobo in the base with a primarily passive cooling method that was simply the long monitor stand made ceramic heat on the new line impossible. A few ceramic G4 Lux Macs exist but the ceramic G4 board was recalled and replaced with a fibre board for free. So by 2003/2004 there really wasn’t any ceramic Power boards remaining for general recycling streams to find. What remains is in the hands of collectors. And not likely to be replaced.
Keep in mind the biggest advantage and disadvantage of ceramic are the same property. Heat flow. It’s the reason Corelle dinnerware can go from a 0• freezer to a 450• oven to a 72• corian counter with no time in between. And why a 256-bit 350TDP chip is implemented in ceramic with active fans and copper pipes. At the same time placing a ceramic card and motherboard in a modern iMac case? Yikes, watch the whole thing melt. Ceramic apple era power chips ran an average temp of 88-94•c. Surrounding board temps reach 50-55• Ceramic power 6 chips can reach 100+c easily. That HP 256 unit is used as an active server moderator. Not a client. And is intended to be used in a cooled server room. Not the spacious living room seen in the few adverts for it. The whole laptop can reach 75-80•. 80c is 175• F for those interested. You definitely aren’t using that in you “lap”. Or on a particle board desk for that matter.
Ceramic has it’s benefits. The same reason it’s use by SpaceX and was used in the NASA shuttles. It can reach obscene temperatures with no shape expansion. Cooling it is a whole different post.
They aren’t gone. Just few and far between. Modern CPUs run as such low TDPs that fibre and even solid plastic works well. I don’t know about Intel because I try not to deal with the company unless I must. But AMD still does “short runs”. You can order 50-500 or so customised implementations (at massive markup) of any chip in their line. Including Ryzen. In ceramic, if you so desire. So if you want to drop five grand per chip to overclock to 8GHz in a mineral oil case have at it. IBM still will do short runs of Power chips in ceramic as well. Don’t get me wrong. If I ever win powerball and megamillions in the same week and had a billion dollars a ceramic g3 R9 sounds like fun despite the $250,000 price tag minimum. I’d buy a giant fish tank and fill it with non conductive mineral oil and led lights and build a R9 kit clocked to 10GHz. Because I could.
But that’s just me. :)
_________________ 42 6F 61 72 64 73 6F 72 74 2E 63 6F 6D
