It is currently Fri Jun 12, 2026 8:23 am
PostPosted: Tue May 19, 2015 12:45 pm
I was told these where all telecom boards but I need to know for sure can anybody please help
PostPosted: Tue May 19, 2015 1:31 pm
All those cards can be put with your gold fingered cards. There is a large variation between the boards in terms of IC population, which would dictate if a board is peripheral or telecom, but as long as you have the gold fingers, you can sell them as gold fingered cards.
PostPosted: Tue May 19, 2015 2:16 pm
Thank you for your response. Do I have to take anything off some of them are heavy
PostPosted: Tue May 19, 2015 3:41 pm
Board 713 has 34 that seem to be "8086 Gold Cap with Gold Legs IC" or at worst "Motorola/Foreign Gold Cap Chips".
they could weight about 1/2 of a pound or more at $110 per pound your odds are better removing them safely with a heat gun. Don't use a chissel or flat head screw driver because you would breaking them.
Board 710 has some white ceramic components with gold plated legs. They only trick is finding out the grade they could be and if it is worth scraping.
PostPosted: Tue May 19, 2015 3:54 pm
thank you
PostPosted: Tue May 19, 2015 6:30 pm
709 finger card
710 telco
711 Finger card
712 finger card
713 gold cap chip board if they are soldered. If they are sockets remove the gold chips for 8086 rate. The rest for ic rate and a gold finger board.
714 gold finger card
715 gold finger card
As 602bridgeway said for 13 if they're soldered and you're comfortable with a heat gun take those chips off. Worth a lot more loose. Just make sure you keep the legs intact.
710. Those white ceramics... not sure where they would fall if loose. Your probably better off leaving it alone and taking telco grade.
PostPosted: Tue May 19, 2015 8:02 pm
I agree with Lostinlodos for the 710 since those ceramic chips are paper thin and not so much weight to make the effort worth. Good to know that it could be graded as Telecom.
PostPosted: Tue May 19, 2015 10:45 pm
Picture 711 is very heavy do I have to take any of the heavy metal off in order to get finger board price I have about 40 of these heavy boards. Thank you all for your help.
PostPosted: Tue May 19, 2015 11:12 pm
That Looks like a power.distribution controll from a server station or terminal. If I'm right there is still a fairly high silver content inside under those metal shells . I don't think Boardsort would have a problem but by all means send Chris an email and ask. We're just users here.
Di NOT try to remove any of those metal caps yourself. The units inside are under pressure. It takes a lot to make them burst but a heat gun can do it (i did) and the stuff inside is nasty.
