It is currently Sat Oct 31, 2026 2:59 am
 Post subject: Boards j
PostPosted: Fri Feb 05, 2021 1:19 pm
Thank you
 Post subject: Re: Boards j
PostPosted: Fri Feb 05, 2021 1:24 pm
Here's my guess:
1) Midgrade
2) Low Grade Peripheral
3) Low Grade Peripheral
4) Peripheral
PostPosted: Fri Feb 05, 2021 1:41 pm
Actually, after seeing that the price list has Low Grade Peripheral category now, I would put 2 and 3 in that category.
PostPosted: Sun Feb 14, 2021 12:54 am
midgrade
low peripheral
high peripheral (i'll expand if asked)
low telco. gold layer memory board
PostPosted: Sun Feb 14, 2021 9:01 am
lostinlodos wrote:
midgrade
low peripheral
Ok I'm curious so can u expand on the high peripheral. ?
PostPosted: Sun Feb 14, 2021 2:38 pm
Well, the chip population alone pulls it into the peripheral classes.
So what else do we have. We have screw tights. Those are usually silver plate.
And three rocker ball dip switches. Those contain either pm balls or pm walls. Silveride is most common balls but I’ve found gold plated nickel balls often enough to always consider them as well. In both cases about $5 per ounce. And about a quarter ounce in weight. Across those switches. Give/take.
If the design uses walls thin clean silver is most common. Though not enough to be going after personally.
So balls walls switches and chips. Lol
So we’ll go ahead an toss this in high peripheral.
