It is currently Tue Aug 04, 2026 2:53 pm
 Post subject: Blood boards
PostPosted: Sat Feb 06, 2021 3:38 am
I just wanted an exciting thread title for the first red board I have ever got. I am also excited to see board sort finally added a category between mid grade and peripheral. I believe so of these would fall into that new $1 a pound category?
 Post subject: Re: Blood boards
PostPosted: Tue Feb 09, 2021 4:29 am
Bumped
PostPosted: Sat Feb 13, 2021 5:58 pm
big midgrade
not so big high peripheral
small low peripheral
big midgrade
small CD/DVD board
big green. midgrade. ports are brass
thin green midgrade. there's just no value to pump it.
port relay board. low peripheral. many clean tin on bell brass in, 30 gold pins out.
demonic sacrifice. the horror. oh the horror.
Actually that board is manufactured by RF Solutions for Biamp Sys Inc. knowing exactly what it is I'll go ahead and say pop ALL the heat sinks off and it'll go high peripheral. The masked over etch is all gold. making this a rare example of a 'known variant' in classing.
Biamp makes semi-custom solutions based on a predefined set of specs in nearly completed products. Systems like Modena and the Tesira integrations set (here) are well known.
btw, if you cut the wires free and left the contacts inside the ports, remove the wire ends. lol. nice try but doesn't work like that. I see atleast two wire ends still connected.
