PostPosted: Tue Feb 16, 2021 11:48 am
still new and learning. watched videos and read about hard drives. was given a dell server, took it apart, had 3 hard drives in it. took 1st one apart and the actuator arm has what looks like gold wire on it. nowhere had said anything about this. please point me in a direction on how to proceed.
File comment: other potential gold I wasn't expecting
File comment: is it gold or gold on copper
File comment: actuator arm
File comment: this is the hard drive
PostPosted: Wed Feb 24, 2021 9:48 pm
not gold. Likely a heavy-tin bronze.
Copper is most common. Sometimes Silveride which is any alloy of Silver that has Silver as the highest single metal. (Old antiques and coinage term).
The arm housing and casing is almost always aluminium. the bolt and pin are normally stainless steel. (peramagnetic high 400 series).
the ride strips ("wire" that connect to the tips can be any number of metals and there's too many options for boardsort to make any listing on it. steel alloys are the most common but I've found silver and nickel. Even gold in really old 8" hard drives, tin in most 5.25 inch drives.
as for the first photo.
the gold flashing wire on the right/centre are gold contact points. you could trim it and put it in high peripheral but it's rather pointless. I don't cut them off any more. the connector on the right. the flashing like most wire and thin board flashing is almost non-measurable. it's literally gold paint. and even less gold than the hardware store gold flake paint.
the plastic connector; the pins on the other hand make things different.
These: gold pins= low peripheral with no aluminium back. gold pin connector with aluminium back and otherwise midgrade.
(last set of three classes is my best experienced guess on breaking up the classes to the new system now, I'm close if not correct).
PostPosted: Thu Feb 25, 2021 9:32 pm
thanks lost. you were out for a bit. hope all is well. glad u are back.
PostPosted: Fri Feb 26, 2021 7:21 am
All is well. CC has reached the point I can take a back seat
PostPosted: Fri Feb 26, 2021 10:26 am
Thanks for the SpamAssault Lost - We'll start calling you "Palladin" (:)
PostPosted: Fri Feb 26, 2021 5:05 pm
Redacted
